FIPS States
When you buy a FIPS feature set with the
Oracle® Enterprise Session Border Controller, the
E-SBC comes equipped
with the FIPS 140-2 feature installed, which operates in FIPS 140-2 compatible
mode (either level 1 or level 2, depending on platform certification). This
means that the
E-SBC has access to the
FIPS capabilities listed in this document.
When FIPS is disabled, the following restrictions are placed on
the
E-SBC:
In the event that any of the power-on or conditional tests fail, the E-SBC becomes completely disabled. If this occurs, you must contact your Oracle representative for instructions on how to proceed.- Security related ACLI elements are not available.
- Security related ACLI commands are not allowed.
