FIPS Feature Set Requirements
The ESBC supports cryptographic capabilities and algorithms compliant with FIPS 140-2 standards. The FIPS feature set, provisioned via the Data Integrity entitlement, is required for the following FIPS-compliant capabilities:
- power-on self tests
- software integrity test
- conditional tests
- ACLI commands and
configuration attributes
- show security fips
- show security ssm-accelerator
- signature-algorithm
