Installing a FIPS Feature Set and Upgrading a FIPS System
This chapter describes the procedure for installing a FIPS feature set
(if one is not already present on the system) and upgrading the image on a
system that already has FIPS provisioned.
You enable the FIPS feature set via the Data Integrity entitlement by way of the setup entitlements command.When enabling the FIPS feature set, the
E-SBC warns the user
with the following message:
CAUTION: Enabling this feature activates enhanced FIPS security functions. Once saved, factory rest may be required.
