Create Custom Filters
You can create single or multiple, custom session filters on the Oracle® Enterprise Session Border Controller (E-SBC) for Monitor and Trace purposes. These filters allow the system to filter incoming and outgoing session data with specific information and then displayed it on the GUI. You can use the custom filters during monitoring on a global basis, or when monitoring session agents and realms.
Use the filter-config object to create custom filters by way of Configure terminal, session-router, filter-config.
The following table lists and describes the attributes that you can configure for each filter.
| Filter | Description |
| filter-config | Use to create a custom filters to be used for Monitor and Trace on the E-SBC. |
| name | Name of the custom filter.
Note: You specify this filter name when configuring global monitoring, SA monitoring, or realm monitoring. |
| address | IP address to filter. Depending on
the value you specify for this attribute, filtering matches the IP address or
IP address and netmask, in the message header. For example:
1.1.1.1 is <IP address> 1.1.1.1/24 is <IP address>/<Netmask> |
| user | Phone number or user-part to filter. Depending on the value you specify for this attribute, filtering matches the phone number string or the user-part with the following header information if it exists in the message: From URI, To URI, Request URI, P-Preferred URI, P-Asserted Identity, P-Associated URI, P-Called Party URI. |
You can define a single or multiple filters with specific names and then specify the filter names to use for global monitoring, session agent monitoring, and realm monitoring.
