Session-recording-server Attribute
To configure the session-recording-server attribute:
In Superuser mode, type
configure terminal and press Enter.
ACMEPACKET# configure terminal -
Type
session-router
and press Enter to access the session router-related objects.
ACMEPACKET(configure)# session-router ACMEPACKET(session-router)# -
Type
and press Enter to access the session recording server-related attributes.
ACMEPACKET(session-router)# session-recording-server ACMEPACKET(session-recording-server)# -
name
— Enter a unique name for the session recording server. This name can be referenced when configuring realm-config, session-agent, and sip-interface. Valid values are alpha-numeric characters. Default is no value specified.
ACMEPACKET(session-recording-server)# name SRS1 -
(optional)
description
— Enter a description for the session recording server. Valid values are alpha-numeric characters. Default is no value specified.
ACMEPACKET(session-recording-server)# description <recording server name> -
realm
— Enter the realm for which the session recording server belongs. Valid values are alpha-numeric characters. Default is no value specified.
ACMEPACKET(session-recording-server)# realm <realm name>Note:
Oracle recommends that the session recording server be configured in its own realm. -
mode
— Enter the recording mode for the session recording server. Valid values are:
selective (default) - Unique recording server created per communication session
persistent - Not supported.
ACMEPACKET(session-recording-server)# recording-mode selective -
destination
— Enter the destination IP address with IP port (port specification is optional) that defines the SIP address (request URI) of the session recording server. Enter values in the format 0.0.0.0:<port number>. Default is no value specified.
ACMEPACKET(session-recording-server)# destination 172.34.2.3:5060 - port — Enter the port number to contact the session recording server. Valid values are 1024 to 65535. Default is 5060.
transport-method — Enter the protocol that the session recording server uses to accept incoming packets from the session reporting client on the network. Default is DynamicTCP. Valid values are:
- “” - No transport method used. Same as leaving this parameter value blank.
- UDP - User Datagram Protocol (UDP) is used for transport method.
- UDP+TCP - UDP and Transmission Control Protocol (TCP) are used for transport method.
- DynamicTCP - One TCP connection for EACH session is used for the transport method.
- StaticTCP - Only one TCP connection for ALL sessions is used for the transport method. This option saves resource allocation (such as ports) during session initiation.
- DynamicTLS - One Transport Layer Security (TLS) connection for EACH session is used for the transport method.
- StaticTLS - Only one TLS connection for ALL sessions is used for the transport method. This option saves resource allocation (such as ports) during session initiation.
- DTLS - Datagram TLS is used for the transport method.
- TLS+DTLS - TLS and DTLS are used for the transport method.
- StaticSCTP - Only one Stream Control Transmission Protocol (SCTP) connection for ALL sessions is used for the transport method. This option saves resource allocation (such as ports) during session initiation.
ACMEPACKET(session-recording-server)# protocol UDP
Enter done to save the session recording configuration.
ACMEPACKET(session-recording-server)# done
