Dynamic Filter Commands
You can use the ACLI to initiate the following dynamic filtering commands:
- capture start—starts the filters you specify in the filter syntax
- capture stop—stops the filters you specify in the filter syntax
Initiating these commands does not change the values set in the ACLI-configured filters on the Oracle® Enterprise Session Border Controller (E-SBC). The E-SBC uses the dynamic filters until you initiate a stop command.The syntax for the dynamic filter commands are:
capture start <main filter> <subfilter(s)>
capture stop <main filter> <subfilter(s)>
You must enter a
<main
filter> and a
<subfilter(s)>
when initiating the “capture start” and capture stop commands.
The following table identifies the values you can use for each attribute in the command syntax.
| Syntax Attribute | Values |
| <main filter> | global - monitors and captures all
realm <realm name> - monitors and captures everything matching realm session-agent <session-agent name> - monitors and captures everything matching session agent. int-ev <short-session | local-rejection> - monitors and captures everything matching a short- session and/or local-rejection. |
| [<subfilter(s)>] | * - monitors and captures all
sessions.
user <Phone Number or User Part URI> - monitors and captures everything that matches this phone number or user part. addr-prefix <IP address or IP address and netmask> - monitors and captures everything that matches this address or address prefix. |
