PreviousNextJavaScript must be enabled to correctly display this content
Protocol Trace Logs
The only protocol trace logs included at this time are sipmsg.log for SIP. The H.323 system tracing is not included. All of the logs enabled with the call–trace parameter are sent to remote log servers, if you also set the log-filter parameter to logs or all.
