Realm-config Attribute
Use the following procedure to configure the realm-config attribute and enable session recording:
  1. session-recording-server — Enter the name of the session-recording server or the session-recording-group in the realm associated with the session reporting client (Oracle® Enterprise Session Border Controller). Valid values are alpha-numeric characters. Default is no value specified.
    ACMEPACKET(realm-config)# session-recording-server <srs-name>
or
ACMEPACKET(realm-config)# session-recording-server SRG:<group-name>
    The value for this attribute is the name you specified in the session-recording-server attribute. If specifying a session-recording-group, you must precede the group name with "SRG:".
  2. session-recording-required — Enter whether you want a call to be accepted by the Oracle® Enterprise Session Border Controller when recording is not available. The default value is disabled.
    • Enabled — Restricts call sessions from being initiated when a recording server is not available.
    • Disabled (default) — Allows call sessions to initiate even when the recording server is not available.
      Oracle recommends that the session-recording-required parameter remain disabled.
  3. session-max-life-limit — Enter the maximum interval in seconds before the SBC must terminate long duration calls. The value supercedes the value of session-max-life-limit in the sip-interface and sip-config configuration elements and is itself superceded by the value of session-max-life-limit in the session-agent configuration element. The default value is 0 (off/ignored).
    test
