PreviousNextJavaScript must be enabled to correctly display this content
Configuring SIPREC Ping on theOracle® Enterprise Session Border Controller.
To configure SIPREC ping on the
Oracle® Enterprise Session Border Controller, you use the ping-method and the ping-interval objects under call-recording-server. Use the following procedure to configure SIPREC ping on the
To configure SIPREC ping:
In Superuser mode, type configure terminal and press Enter.
ping-method—Enter the message or method type for which the Net-Net ESD uses in a ping request to the SRS to determine if it is reachable or not. Default is blank. Valid values are:
BYE
OPTIONS
UPDATE
SUBSCRIBE
CANCEL
NOTIFY
ping-interval—Enter the amount of time, in seconds, that the Net-Net ESD waits before it pings the SRS in subsequent intervals. Valid values are 0 to 99999. Default is 0 (zero). The setting of zero disables the ping interval.
