Interesting Events Configuration
To configure interesting events:
In Superuser mode, type
configure terminal and press Enter.
ACMEPACKET# configure terminal -
Type
session-router and press Enter to access the
session router-related objects.
ACMEPACKET(configure)# session-router ACMEPACKET(session-router)# -
Type
session-router again and press Enter to access
the session router configuration-related attributes.
ACMEPACKET(session-router)# session-router ACMEPACKET(session-router-config)#short-session-duration—Enter the maximum session duration, in seconds, to be considered a short session. Default is 0 (disabled). Valid values are 0 to 999999999.
ACMEPACKET(session-router-config)# short-session-duration 30 -
Enter
done to save the filters.
ACMEPACKET(session-router-config)# done ACMEPACKET(session-router-config)# -
Enter
exit to exit the interesting-events
configuration.
ACMEPACKET(session-router-config)# exit ACMEPACKET(session-router)# -
Type
sip-monitoring and press Enter to access the
SIP monitoring-related attributes.
ACMEPACKET(session-router-config)# sip-monitoring ACMEPACKET(sip-monitoring)# -
Type
select and press Enter.
ACMEPACKET(sip-monitoring)# select ACMEPACKET(sip-monitoring)# -
Type
interesting-events and press Enter to access
the interesting events-related attributes.
ACMEPACKET(sip-monitoring)# interesting-events ACMEPACKET(interesting-events)#type—Enter the type of interesting event you for which you want to filter. Default is blank and disables this filter. Valid values are:
short-session
local-rejection
ACMEPACKET(interesting-events)# type short-sessiontrigger-threshold — (optional) Enter the number of interesting events that must occur within the time set by the trigger window value. If the number of events reaches the trigger-threshold during the trigger-window time, monitoring is started.Default is 0 (disabled). Valid values are 0 to 999999999.
ACMEPACKET(interesting-events)# trigger-threshold 50trigger-timeout —Sets the amount of time, in seconds, that the trigger is active once monitoring has started. If no interesting events occur in the time frame set for this value, monitoring never starts. Default is 0 (trigger always on). Valid values are 0 to 999999999.
ACMEPACKET(interesting-events)# trigger-timeout 30
Enter done to save the filters.
ACMEPACKET(interesting-events)# done -
Enter exit to exit the interesting-events
configuration.
ACMEPACKET(interesting-events)# exit -
Enter exit to exit the sip-monitoring
configuration.
ACMEPACKET(sip-monitoring)# exit -
Enter done to save the configuration.
ACMEPACKET(session-router)# done -
Enter exit to exit the session-router
configuration.
ACMEPACKET(session-router)# exit -
Enter exit to exit the configure mode.
ACMEPACKET(configure)# exit -
Enter save-config to save the filters.
ACMEPACKET# save-config -
Enter activate-config to activate the
filters in the current configuration.
ACMEPACKET# activate-config
