Sip-interface Attribute
To configure the sip-interface attribute and enable session recording:
In Superuser mode,
type
configure
terminal and press Enter.
ORACLE# configure terminal
Type
session-router
and press Enter to access the session router-related
objects.
ORACLE(configure)# session-router ORACLE(session-router)#
Type
sip-interface
and press Enter to access the SIP interface-related
attributes.
ORACLE(session-router)# sip-interface ORACLE(sip-interface)#
session-recording-server
— Enter the name of the session-recording server or the
session-recording-group to apply to the SIP interface on the session recording
client (Oracle® Enterprise Session Border Controller). Valid values are alpha-numeric characters. Default
is no value specified.
ORACLE(sip-interface)# se ss on-recording-server SRG:<session recording server name or session-recording group name>
The value for this attribute is the name you specified in the session-recording-server attribute. -
session-recording-required
— Enter whether or not you want a call to be accepted by
the
Oracle® Enterprise Session Border Controller if recording is not available. Valid values are:
Enabled - Restricts call sessions from being initiated when a recording server is not available.
Disabled (default)- Allows call sessions to initiate even if the recording server is not available.
ORACLE(sip-interface)# session-recording-required disabled
Oracle recommends that the session-recording-required parameter remain disabled. -
Enter exit to exit the
SIP interface configuration.
ORACLE(sip-interface)# exit
session router configuration.
ORACLE(session-router)# exit
configure mode.
ORACLE(configure)# exit
Enter save-config to save
the SIP interface configuration.
ORACLE# save-config
Enter activate-config to
activate the SIP interface configuration.
ORACLE# activate-config
