Configuration Element Changes
The following topics explain changes to configuration elements. The system may process some changes, while others may require you to intervene.
Attribute Name Changes for session-agent Configuration
For PCZ3.0.0, Oracle changed the names of several attributes in the session-agent configuration. Updating the schema resolves the changes, but if you try to upload a .csv file of session-agents with the previous attribute names you will see errors. To avoid errors, update the column header names in the .csv file to match the new attribute names before uploading the .csv file. Note that the order of the attributes in the configuration is different for PCZ3.0.0, but you do not need to re-order the attributes in the .csv file. The following table lists the attribute names prior to PCZ3.0.0 and the corresponding new names.
| Prior to PCZ3.0.0 | As of PCZ3.0.0 |
| IP-address | ip-address |
| transport-protocol | transport-method |
| inbound-header-manipulation | in-manipulationid |
| outbound-header-manipulation | out-manipulationid |
| OPTIONS-ping-interval | ping-interval |
| enable-REFER-termination | refer-call-transfer |
| Send-NOTIFY-for-REFER-provisional-responses | refer-notify-provisional |
| enable-constraints | constraints |
| maximum-sessions | max-sessions |
| maximum-inbound-sessions | max-inbound-sessions |
| maximum-outbound-sessions | max-outbound-sessions |
| maximum-burst-rate | max-burst-rate |
| maximum-inbound-burst-rate | max-inbound-burst-rate |
| maximum-outbound-burst-rate | max-outbound-burst-rate |
| burst-rate-window-size | register-burst-window |
| maximum-sustain-rate | max-register-sustain-rate |
| maximum-inbound-sustain-rate | max-inbound-sustain-rate |
| maximum-outbound-sustain-rate | max-outbound-sustain-rate |
| sustained-rate-window-size | sustain-rate-window |
| SPL-options | spl-options |
