Caveats, Limitations, and Known Issues
Oracle recommends that you review the following information about Caveats, Limitations, and Known Issues before using the E-CZ8.1.0 release. The Caveats and Limitations topics explain certain behaviors and limitations that you can expect. They do not provide workarounds. The Known Issues topic describes issues that Oracle is aware of and may address in a future release. Known Issues contain workarounds, when available.
Older Caveats Fixed in This Release
- QoS reporting is now supported for transcoded calls
The following information lists and describes the caveats and limitations for this release. Oracle updates this Release Notes document to distribute issue status changes. Check the latest revisions of this document to stay informed about these issues.
Provisioning Transcode Codec Session Capacities
When you use setup entitlements to set the capacity for a transcode codec, the system may or may not require a reboot.
- When a transcode codec is licensed with a license key, a capacity change requires a reboot to take effect.
- When a transcode codec is not licensed with a license key, a capacity change takes effect without a reboot.
Virtual Network Function (VNF) Caveats
The following functional caveats apply to VNF deployments of this release:
- The OVM server 3.4.2 does not support the virtual back-end required for para-virtualized (PV) networking. VIF emulated interfaces are supported but have lower performance. Consider using SR-IOV or PCI-passthru as an alternative if higher performance is required.
- Default levels for scalability and are set to ensure appropriate throttling based on platform capacity factors such as hypervisor type, number and role of CPU cores, available host memory and I/O bandwidth. In some scenarios, the defaults may not be appropriate and throttling may occur at lower or higher call rates than expected. Please contact Oracle Technical Support for details on how to override the default throttles, if required.
- To support HA failover, MAC anti-spoofing must be disabled for media interfaces on the host hypervisor/vSwitch/SR-IOV_PF.
- When operating as a VNF deployed in an HA configuration, the OCSBC does not support IPSec.
- Virtual LAN (VLAN) tagging is not supported when deploying the OCESBC over the Hyper-V platform.
Transcoding - general
Only SIP signaling is supported with transcoding.
Codec policies can be used only with realms associated with SIP signaling.
Local Media Playback feature is incompatible with any transcoding functionality.
T.38 Fax Transcoding
T.38 Fax transcoding is available for G711 only at 10ms, 20ms, 30ms ptimes.
Pooled Transcoding for Fax is unsupported.
Pooled Transcoding
Lawful intercept
2833 IWF
Fax scenarios
RTCP generation for transcoded calls
OPUS/SILK codecs
SRTP and Transcoding on the same call
Asymmetric DPT in SRVCC call flows
Media hairpinning
QoS reporting for transcoded calls
Multiple SDP answers to a single offer
PRACK Interworking
Asymmetric Preconditions
DTMF Interworking
RFC 2833 interworking with H.323 is unsupported.
SIP-KPML to RFC2833 conversion is not supported for transcoded calls.
H.323 Signaling Support
If you run H.323 and SIP traffic in system, configure each protocol (SIP, H.323) in a separate realm.
Media Hairpinning
Media hairpining is not supported for hair-pin and spiral call flows involving both H.323 and SIP protocols.
Fragmented Ping Support
The Oracle® Enterprise Session Border Controller does not respond to inbound fragmented ping packets.
Physical Interface RTC Support
After changing any Physical Interface configuration, you must reboot the system reboot.
SRTP Caveats
The ARIA cipher is not supported by virtual machine deployments.
Packet Trace
- VNF deployments do not support the packet-trace remote command.
- The Acme Packet 3900 does not support the packet-trace remote command.
- The Acme Packet 1100 does not support the packet-trace remote command.
- Output from the packet-trace local command on hardware platforms running this software version may display invalid MAC addresses for signaling packets.
Trace Tools
- packet-trace command
- The communications-monitor as an embedded probe with the Enterprise Operations Monitor
- SIP Monitor and Trace
RTCP Generation
Video flows are not supported in realms where RTCP generation is enabled.
SCTP
SCTP Multihoming does not support dynamic and static ACLs configured in a realm.
SCTP must be configured to use different ports than configured TCP ports for a given interface.
Real Time Configuration Issues
In this version of the E-SBC, the realm-config element's access-control-trust-level parameter is not real-time configurable.
Workaround: Make changes to this parameter within a maintenance window.
Virtual Network Function (VNF) Limitations
Oracle® Enterprise Session Border Controller (E-SBC) functions not available in VNF deployments of this release include:
- Native transcoding for
codecs other than G.711, G.729 and AMR.
Workaround: For all other codecs, configure your environment and system for pooled transcoding.
- FAX Detection
- RTCP generation for G.711 or G.729
- RTCP detection
- TSCF functionality
- Remote Packet Trace
- ARIA Cipher
- IPSec functionality not
available in VNF deployments of this release:
- IKEv1
- Authentication header (AH)
- The AES-XCBC authentication algorithm
- Dynamic reconfiguration of security-associations
- Hitless HA failover of IPSec connections.
High Availability
- Create the SIP interface or Session Recording Server on the primary E-SBC, and save and activate the configuration.
- Reboot both the Primary and the Secondary.
Acme Packet 3900 IPSec Limitations
The following IPSec functions are not available for the Acme Packet 3900 in this release.
- IKEv1
Dead Peer Detection
When running on the Acme Packet 6100, the E-SBC's dead peer detection does not work with IPv4.
Offer-Less-Invite Call Flow
Call flows that have "Offer-less-invite using PRACK interworking, Transcoding, and dynamic payload" are not supported in this release.
Fragmented SIP Message Limitations
Fragmented SIP messages are intercepted but not forwarded to the X2 server if IKEv1/IPsec tunnels are configured as transport mode.
Workaround: Configure IKEv1/IPsec tunnels as "tunnel mode".
IPv6 On X1 Interface
IPv6 does not work on X1 interface.
Known Issues
The following list of Known Issues provides the Bug DB number, a description of the issue, and when possible, the workaround, the found-in release, and the fixed-in release.
| ID | Description | Found-in | Fixed-in |
| 29937232 |
GW unreachable and NetBufCtrl MBUFF errors - This can result in system instability including crash, gw-unreachable and redundancy issues. System will switchover if in HA. Show Buffers output will normally show an increase of errors reported in the NetBufCtrl field due to mbuf’s not being freed. |
E-Cz8.1.0 | E-Cz8.1.0m1p18 |
None |
The system does not support SIP-H323 hairpin calls with DTMF tone indication interworking. | SCZ7.2.0 | CZ8.1.0 |
| None | The
E-SBC stops responding
when you configure an H323 stack supporting SIP-H323-SIP calls with its
max-calls parameter
set to a value that is less than its
q931-max-calls
parameter.
Workaround: For applicable environments, configure the H323 stack max-calls parameter to a value that is greater than its q931-max-calls parameter. |
SCZ7.4.0 | TBD |
| None | The system does not support HA Redundancy for H.323 calls. | TBD | |
21805139 |
RADIUS Stop records for inter-working function (IWF) calls might display inaccurate values. | SCZ7.3.0 | TBD |
22322673 |
When running in an HA configuration, the
secondary
E-SBC might go out of
service (OoS) during upgrades, switchovers, and other HA processes while
transitioning from the "Becoming Standby" state. Oracle observes such behavior
in approximately 25% of these circumstances. You can verify the issue with
log.berpd, which can indicate that the media did not synchronize.
Workaround: Reboot the secondary until it successfully reaches the "Standby" state. |
SCZ7.3.0P1 | TBD |
24574252 |
The show interfaces brief command incorrectly shows pri-util-addr information in its output. | SCZ7.4.0 | TBD |
24809688 |
Media interfaces configured for IPv6 do not support multiple VLANs. | SCZ7.3.0 | TBD |
25954122 |
Telephony fraud protection does not black list calls after a failover. Workaround: Activate the fraud protection table on the newly active server. |
E-CZ7.5.0 | TBD |
26136553 |
The E-SBC can incur a system-level service impact while performing a switchover using "notify berpd force" with an LDAP configuration pointing to an unreachable LDAP server. Workaround: Ensure that the E-SBC can reach the LDAP server before performing switchover. |
Unknown | TBD |
26260953 |
Enabling and adding Comm Monitor config for
the first time can create a situation where the monitoring traffic (IPFIX
packets) does not reach the Enterprise Operations Monitor.
Workaround: Reboot the system. |
E-CZ7.5.0 | TBD |
26281599 |
The system feature provided by the
phy-interfaces's
overload-protection
parameter and
overload-alarm-threshold
sub-element is not functional. Specifically, enabling the protection and
setting the thresholds does not result in trap and trap-clear events based on
the interface's traffic load.
The applicable ap-smgmt.mib SNMP objects include:
SCZ7.2.0 | SCZ8.2.0 |
26313330 |
In some early media call flows, the E-SBC might not present the correct address for RTP causing the call to terminate. | SCZ8.0.0 | SCZ8.0.0p2 |
26316821 |
When configured with the 10 second QoS update mechanism for OCOM, the E-SBC presents the same codec on both sides of a transcoding call in the monitoring packets. You can determine the correct codecs from the SDP in the SIP Invite and 200 OK. |
SCZ8.0.0p1 | TBD |
26323802 |
The 10s QoS interim feature includes the wrong source IP address as the incoming side of a call flow. The issue does not prevent successful call and QoS monitoring. For monitoring and debugging purposes, you can find the source IP in the SIP messages (INVITE/200OK). |
SCZ8.0.0p1 | TBD |
26338219 |
The packet-trace remote command does not work with IPv6. | S-CZ7.4.0 | TBD |
| 26432028 | On the Acme Packet 1100, Acme Packet 3900,
and VME un-encrypted SRTP-SDES calls result in one-way audio.
Workaround: None at this time. |
E-CZ7.5.0 | TBD |
26497348 |
When operating in HA mode, the E-SBC might display extraneous "Contact ID" output from the show sipd endpoint-ip command. You can safely ignore such output. | SCZ8.0.0 | TBD |
26669090 |
The E-SBC dead peer detection does not work with IPv4. | SCZ8.0.0 | TBD |
26790731 |
Running commands with very long output, such as the "show support-info" command, over an OVM virtual console might cause the system to reboot. Workaround: You must run the "show support-info" command only over SSH. |
SCZ8.0.0p1 | TBD |
27031344 |
When configured to perform SRTP-RTP interworking, the E-SBC might forward SRTP information in the SDP body of packets on the core side, causing the calls to terminate. Workaround: Add an appropriately configured media-sec-policy on the RTP side of the call flow. This policy is in addition to the policy on the SRTP side of the call flow. |
SCZ8.0.0p1 | TBD |
| 27240195 |
The cpu-load command does not display the correct value under show-platforms. |
ECZ8.0.0 | CZ8.1.0 |
26338219 |
In some PRACK IWF scenarios, the E-SBC may insert the media address of the core in the 200 OK SDP sent to the caller instead of it's own address. This misdirects the audio causing the call to fail. | CZ8.1.0 | |
| If you configured the ims_aka option, you must also configure sip-interfaces with an ims-aka-profile entry. | ECZ7.4.0m1 | ||
27795586 |
When running E-CZ8.1.0 over Hyper-V, and you
set the process-log level to DEBUG, the system can become unstable or stop
responding. The system requires a reboot.
Workaround: Do not enable process-log level DEBUG. |
ECZ8.1.0 | CZ810p1 |
27539750 |
When trying to establish a connection between
the SBC and your network, while using TLS version 1.2, the SBC may reject the
connection.
Workaround: You may need to adjust your cipher list. |
ECZ8.1.0 | TBD |
| 28062411 | Calls that require SIP/PRACK interworking as invoked by the 100rel-interworking option on a SIP interface do not work in pooled transcoding architectures. | SCZ740 | SCZ810m1 |
| None | IPSec is not supported on the Acme Packet
3900 and VNF in the CZ8.1.0 release. You must upgrade to CZ8.1.0p1 to get this
support. After you upgrade to CZ8.1.0p1, do the following:
CZ810 | CZ810p1 |
| 28305575 | On VNFs, the system erroneously displays the IPSEC entitlement under "Keyed (Licensed) Entitlements." The error does not affect any functionality and you do not need to do anything. | CZ810 | CZ820 |
28367500 |
When operating the OCSBC on the Acme Packet 6300, the traceroute command does not show hops for an IPv6 traceroute that does not reach the target address. The system successfully displays hops when the traceroute reaches the target and for IPv4 traceroutes. | CZ810 | TBD |
28475320 |
When running ECZ810M1 on the Acme Packet 3900, IPSec functionality is not available. | CZ810 | TBD |
28617938 |
The
anonymize-invite
option for CommMonitor is not RTC. To see a change, you must either reboot or
toggle the admin state. The following is a general admin state toggle
procedure:
CZ810m1 | TBD |
28618563 |
The system is not populating the Username AVP in Accounting Requests (ACRs) correctly. When triggered by an INVITE, these AVPs contain only the "@" sign. They do not include the username and domain name portion of the URL. | CZ810m1 | TBD |
28659469 |
When booting CZ8.1.0M1 on any virtual
platform, not all system processes start. This known issue only occurs on
initial boot, and not in an upgrade scenario.
Workaround: Reboot the E-SBC a second time, after it initially starts. |
CZ810m1 | TBD |
29931732 |
The embedded communications monitor probe does not send IPv6 traffic to the Oracle Communications Operations Monitor's mediation engine. | SCZ800 | TBD |
| 28820258 |
When running TLS Chat on VMware-PV 4core (SSFD) + 16GB, TLS Chat sessions are gradually decreasing. When looking in Wireshark at EXFO, EXFO forwards a wrong TLS MSRP Chat payload to EXFO UAS. TCP Chat doesn't have this error. |
E-CZ800 | TBD |
| ID | Description | Found In | Fixed In | |
27700933 |
The system does not support TSM. |
N/A | N/A | |
27700607 |
When recording transcoded streams under load, sometimes the recorder might receive only a single stream. |
N/A | N/A | |
| 28071326 |
Calls that require LMSD interworking as invoked by the lmsd-interworking option on a SIP interface do not work in pooled transcoding architectures. During call establishment, when sending the 200 OK back to the original caller, the cached SDP is not included. |
N/A | N/A | |
| N/A | The T.140-Baudot Relay is not excluded from pooled transcoding support. | N/A | N/A | |
