Image Files and Boot Files
For Engineered Hardware
Use the following files for new installations and upgrades on Acme Packet platforms.
- Image file:
nnECZ810.bz. - Bootloader file:
nnECZ810.boot.
For Virtual Machines
The E-SBC E-CZ8.1.0 version includes distributions suited for deployment over hypervisors. Download packages contain virtual machine templates for a range of virtual architectures. Use the following distributions to deploy the E-SBC as a virtual machine:nnECZ810-img-vm_ovm.ova—Open Virtualization Archive (.ova) distribution of the E-SBC VNF for Oracle (XEN) virtual machines.nnECZ810-img-vm_kvm.tgz—Compressed image file including E-SBC VNF for KVM virtual machines.nnECZ810-img-vm_vmware.ova—Open Virtualization Archive (.ova) distribution of the E-SBC VNF for ESXi virtual machines.nnECZ810-img-vm.vhd—Virtual Hard Drive (.vhd) distribution of the E-SBC VNF for Hyper-V virtual machines.nnECZ810_HOT.tar.gz—The Heat Orchestration Templates used with OpenStack.
The Oracle (XEN) Virtual Machine, KVM, and ESXi packages include:
- Product software—Bootable image of the product allowing startup and operation as a virtual machine. This disk image is in either the vmdk or qcow2 format.
usbc.ovf—XML descriptor information containing metadata for the overall package, including identification, and default virtual machine resource requirements. The .ovf file format is specific to the supported hypervisor.legal.txt—Licensing information, including the Oracle End-User license agreement (EULA) terms covering the use of this software, and third-party license notifications.
