Self-Provisioned Entitlements
You enable the features that you purchased from Oracle by way of self-provisioning. Using the setup entitlements command, you provision the feature by either entering "enabled" or by setting the number of sessions allowed.
Self-Provisioned Features
The following table lists the features that you can self-provision,
and the corresponding type of enablement required.
| Feature | Type |
| Administrative security | Enabled or Disabled |
| Advanced | Enabled or Disabled |
| SIP sessions | Number of sessions |
| Data integrity (FIPS) | Enabled or Disabled |
| Advanced Security Suite (JITC) | Enabled or Disabled |
| Transcode AMR-NB | Number of sessions |
| Transcode AMR-WB | Number of sessions |
| Transcode EVRC | Number of sessions |
| Transcode EVRC-B | Number of sessions |
| Transcode EVS | Number of sessions |
| Transcode Opus | Number of sessions |
| Transcode SILK | Number of sessions |
Use the show entitlements command to see a list of provisioned features and their session capacities.
Use the show features command to see a list of all enabled features and the total session capacity.
