NIU and Feature Group Requirements
The following tables list the feature groups for all Oracle® Enterprise Session Border Controller (E-SBC) hardware and virtual platforms that require a specific Network Interface Unit (NIU). The left column lists the supported NIUs. The other columns represent feature sets. In the table cells, the check mark character ( ✓) indicates a feature set that requires the corresponding NIU listed in the left column. The x character in a table cell indicates a feature set that does not require the NIU. Some cells contain text that says, "Not applicable."
Table 1-1 Acme Packet 1100 NIU and Feature Group Support Matrix
| NIU | IPSec | SRTP | QoS | Transcoding | ISDN PRI | ISDN BRI | Analog POTS |
| Acme Packet 1100 Ethernet interface | ✗ | ✓ | ✓ | ✓ (requires transcoding module) | ✗ | ✗ | ✗ |
| Acme Packet 1100 TDM interface (single port and quad port) | Not applicable | Not applicable | Not applicable | Not applicable | ✓ | ✗ | ✗ |
| Acme Packet 1100 Euro ISDN BRI interface | Not applicable | Not applicable | Not applicable | Not applicable | ✗ | ✓ | ✗ |
| Acme Packet 1100 Analog POTS interface | Not applicable | Not applicable | Not applicable | Not applicable | ✗ | ✗ | ✓ |
Table 1-2 Acme Packet 3900 NIU and Feature Group Support Matrix
| 4x1Gig | ✓ | ✓ | ✓ | ✓ (requires transcoding module) | ✗ |
| Quad-Span TDM interface | Not applicable | Not applicable | Not applicable | Not applicable | ✓ |
Table 1-3 Acme Packet 4600 NIU and Feature Group Support Matrix
| 4x1Gig or 2x10Gig NIU | ✓ | ✓ | ✓ | ✓ (requires transcoding module) |
Table 1-4 Acme Packet 6300 NIU and Feature Group Support Matrix
| 2x10Gig NIU | ✓ | ✓ | ✓ | ✓ Transcoding Carrier Unit |
Table 1-5 Virtual Machine and Feature Group Support Matrix
| IPSec | SRTP | QoS | Transcoding | |
| Virtual Machine | ✓ | ✓ | ✓ | ✓ (AMR, G729, PCMU, PCMA) |
