Behavioral Changes
The following information documents the behavioral changes to the Oracle® Enterprise Session Border Controller (E-SBC) in this software release.
Provisioning FIPS
To downgrade to a previous release that does not support SHA-2 hashing, use the show version boot command to get the serial number of your E-SBC and contact Oracle Support.
In previous releases, you needed a license key to enable the FIPS feature set. As of E-CZ8.1.0, you enable the FIPS feature set by way of self-provisioned entitlements using setup entitlements, You must use this method when adding FIPS on a new system.NAPTR Follow-Up Queries for A Records
The E-SBC can issue a query for either S or A records, based on the response to an E-SBC request within a NAPTR resource record. This happens if the E-SBC needs more information to reach its target FQDN. Previously, the system always issued queries for S records.
SNMPv3
With this software version, you configure SNMP traps within the context of the E-SBC's comprehensive SNMPv3 support.
The secure-traps value is removed from the snmp-agent-mode parameter, which is part of the system-config.
In addition, the elimination of secure-traps means that the following protocols are deprecated for use by SNMP:
- DES privacy protocol
- MD5 and SHA authentication protocols
To configure traps, refer to SNMP configuration information in the MIB Reference Guide.
TLS1.0
TLS 1.0 sessions fail to negotiate when the tls-version parameter is set to compatibility. To advertise TLS1.0 during session negotiation, navigate to the security-config element and set the options parameter to +sslmin=tls1.0.
ORACLE(security-config)# options +sslmin=tls1.0
HMR Regex Matching Changes
The PCRE (Perl Compatible Regular Expression) engine was updated in
8.1 and consequently the
match-value value of
\, is
no longer valid. In previous releases, the PCRE engine used
\, to
match any character, including a NUL character. The newer PCRE engine does not
support
Separate from the PCRE, the SBC supports the non-standard
\,+ to
match one or more characters, including NUL characters. If your HMR rule for
8.0 or earlier depends on
\, (for
example,
use either the standard
.* to
match any character zero or more times, excluding NUL characters, or use
\,+ to
match any character, including NUL characters, one or more times.
Voltage Monitoring
Starting in S-Cz8.1.0m1p6 and later, apEnvMonVoltageStatusValue in the ap-env-monitor.mib file is not supported. Voltage can still be monitored through the ACLI show voltage command.
