Basic Rate Interface Configuration
The Acme Packet 1100 supports the optional analog Euro-ISDN Basic Rate Interface (BRI) interface for lower call-volume customers who want to connect their BRI Lines, analog trunk lines, analog phones, fax machines, and other analog communications devices to their IP PBX/IP telephony systems. The BRI interface supports fewer channels than the Primary Rate Interface (PRI) interface, but it can support two calls at the same time on one line. The BRI interface supports 2 b-channels for voice and user data at 128 Kbit/s and 1 d-channel for signaling.
When the system detects the BRI the interface, it displays the corresponding configuration parameters in tdm-config and tdm-profile. The tdm-config element supports creating multiple TDM profiles with different names, so that you can create more than one BRI span configuration for more targeted routing. The tdm-profile sub-element supports enabling a particular span as the timing source, enabling echo cancellation for improved audio quality, and assigning profiles to routing groups. When configuring multiple tdm-profiles, you can create a profile for each span individually or assign multiple spans to one profile. You can assign the profiles to a route group with either the same number or a different number per profile. For example you can configure a call to go to tdm:profileName, tdm:span:1 or tdm:group:2. You can send the call to a specific tdm interface or a group of them.
Span Configuration
TDM supports up to four profiles with the BRI interface, so that you can apply a TDM profile to each span. You can configure each span exclusively or set several spans (up to four) to share the same configuration. Each span represents a physical network interface. The span-number parameter in tdm-profile indicates the interface to which the profile applies. For example, span-number = 1,2,3,4 means that the profile applies to all spans. span-number = 1 means that the profile applies only to span 1. You can specify more than one span and fewer than four spans in the same profile, for example, span-number = 1,2. During configuration, the system validates that a particular span is assigned to only one profile.
Signaling Configuration
Depending on your deployment, you might need the Oracle® Enterprise Session Border Controller (E-SBC) to act as the customer premises equipment (CPE) side of the connection or to act as the network (NET) side of the connection.
- The E-SBC can act as the network (NET) side of the deployment and connect to a PBX.
- The E-SBC can act as the equipment (CPE) side of the deployment and connect to a network provider's ISDN line.
The system supports the coexistence of multiple profiles for both CPE and NET, and you can configure up to four profiles each.
Routing Configuration
For control over routing TDM traffic, each TDM profile includes the route-group number parameter that you can use to group profiles together for routing. You can route traffic by setting the following parameters for next-hop in the local-policy configuration:
next-hop = tdm:span:<number> Use span number to specify routing endpoints.
next-hop = tdm:group:<number> Each TDM profile includes route-group number, so that you can group profiles together. The route-group number can address several profiles for routing. During routing, the embedded Asterisk software that the E-SBC uses to connect PSTN and VoIP phone services to each other picks the first available span and the first available channel when routing to a group.
next-hop= tdm:<profileName> During configuration, the system checks to confirm that no other profile contains the same routing.
Configure the Basic Rate Interface
To configure the Basic Rate Interface (BRI) card, you must set the parameters in tdm-config and tdm-profile under system. Note that the system supports coexisting profiles for both bri_cpe (Customer Premises Equipment) and bri_net (Network). After you create the configuration, you must run either the Set TDM Configuration wizard from the Web GUI or the setup tdm command from the ACLI to complete the configuration.
- Confirm the presence of the BRI interface on the Acme Packet 1100.
- Plan the number of TDM profiles that you want. (You can add or delete profiles later, if your needs change.)
When the Oracle® Enterprise Session Border Controller (E-SBC) detects the BRI interface, it displays the corresponding parameters and inserts certain values that you cannot change.
- Run the TDM configuration wizard.
- Configure the inbound and outbound TDM local policies.
