ACLI Show Commands for TDM
Time Division Multiplexing (TDM) uses a unique set of ACLI "show" commands to provide information about the TDM configuration and its operations.
The following TDM
"show" commands work only on the Acme Packet 1100 and Acme Packet 3900
platforms with a TDM card installed. No other
Oracle® Enterprise Session Border Controller platforms recognize the TDM "show" commands. Oracle
recommends using show commands for troubleshooting, and only with guidance from
Oracle support technicians.
| show running-config tdm-config | Displays the tdm-config element, which is located under system. |
| show running-config tdm-profile | Displays the tdm-profile sub-element, which is located under tdm-config. |
| show tdm spans | Displays the following states for TDM spans:
| show tdm <span # > | Displays the state and configuration profile of a specified span. |
| show tdm channels | Displays the following information about the TDM
channels:
| show tdm channel # | Displays the profile of the specified channel. |
| show tdm status | Displays the enablement status of State and Logging, plus the TDM profile. |
| show tdm dialplan | Displays the TDM dial plan. |
