Table of Contents
1. Preface
  • 1.1 Prerequisites
  • 1.2 Audience
  • 1.3 Conventions Used
  • 2. Installing WebServices Database Objects
    3. Deploying Application Interface WebServices
  • 3.1 Creating Data Sources for WebServices
  • 3.2 Working with SSL
  • 3.2.1 Steps to Import Certificates to keystore
  • 3.2.2 Enable SSL Debugging
  • 3.2.3 Connecting to service supporting only TLS protocol
  • 3.3 Create RouteOne Credentials and System Policies
  • 3.4 Deploying Webservices
  • 3.4.1 Deployment of WebServices in Enterprise Manager
  • 4. Configuring Weblogic Policy on WebServices
    5. Verifying Successful Installation
  • 5.1 Steps to Verify Successful Webservices deployment:
  • 5.2 Steps to Verify Successful Interface (Route One) deployment:
  • 6. Enable Logging
  • 6.1 Enabling WebService Log
  • 6.2 Enabling SQL Log for WebServices Component
  • 7. Configuring RESTful WebService
  • 7.1 Create Data Sources for RESTful WebService
  • 7.2 Deploy RESTful WebService
  • Appendix A: Configuration parameters
