| Siebel CRM Assignment Manager Administration Guide Siebel 2018 E24725-01 |
![]() Previous |
![]() Next |
View PDF |
If you do not want Siebel Assignment Manager to reassign the organizations that you have set up for an account, then you must change the default property values for the Account assignment object in Siebel Tools.
Note: The following procedure is also valid for other objects such as Contact and Opportunity. |
To stop reassignment of organizations for accounts
Start Siebel Tools.
In the Object Explorer, expand Workflow Policy Object.
In the Workflow Policy Object list, select Account.
In the Object Explorer, click Assignment Object.
In the Assignment Objects list, set the following values:
Default Organization = blank
Org Primary Column = blank
Org Table = blank
Set Primary Org = FALSE
where blank is a null value.
After these values are set, Assignment Manager does not reassign any organizations for accounts.
Run various server administration tasks.
For instructions, see Steps 2 and 3 of the procedure in "Updating Your Siebel Assignment Manager Deployment with New Configurations".
Note: It is not necessary to redeploy the Siebel runtime repository. However, you must check in the changes to the server database. |
