| Siebel CRM Assignment Manager Administration Guide Siebel 2018 E24725-01 |
![]() Previous |
![]() Next |
View PDF |
This topic gives one example of creating an assignment rule that evaluates a service request object and assigns the object to the highest-scoring employee based on the employee's skill level and availability. You might use this feature differently, depending on your business model.
The service request object, which is often associated with a job, a finite time period, and a specific owner, is an example of an object that can be assigned using Assignment Manager's availability-based assignment feature.
To use the availability assignment feature, certain setup procedures must be performed in the Siebel Field Service application before creating the assignment rule. For more information about this feature and its requirements, see "About Availability-Based Assignment". Several configurations must also be made to the assignment object before using the availability feature. See "Process of Configuring Assignment Objects for Availability-Based Assignment".
The following procedures assume that a service region (California Service Region), employees (West Coast Service Representative and West Coast Service Manager), and a product (Pentium III Desktop) are already defined. For information about defining service regions, see Siebel Field Service Guide.
Use the following procedure to set up the Siebel Field Service application for availability assignment.
To set up the Field Service application for availability assignment
Verify that a schedule exists with valid hours by navigating to the All Schedules view (Administration - Service screen, Schedules view).
For this example, select the 12x5 Support schedule in the Schedules List, and click the Schedule Hours view tab. Make sure that the hours listed are valid. The following figure shows this view (the Schedule Hours view tab).
Set up a Service Region.
Navigate to the Administration - Scheduling screen, and then the Service Regions view. For this example, select the California Service Region. In the Schedule field, select 12x5 Support.
Set up the parameter set for the Service Region.
With California Service Region selected, navigate to the Parameters Sets view (in the Administration - Scheduling screen). For this example, select the West Coast Parameters used by the California Service Region, and then click the Parameters tab. Update the following parameter records:
ABS Days to Start = 0
ABS Days to End = 20
ABS Logging Level = 4
Set up server key mappings by navigating to the Server Key Mappings view in the Administration - Scheduling screen.
For this example, create a new record and save it with the following field values:
Server = Siebel Server
Process # = 0
Service Region = California Service Region
Component = ApptBook
Associate employees to the service region by navigating to the Administration - User screen, and then the Employees view.
For this example, select the West Coast Service Representative and the West Coast Service Manager and click the Field Service Details tab. Edit the Schedule and Service Region fields with 12x5 Support and California Service Region, respectively.
Note: If service regions are modified or deleted, then you must release assignment rules to update the rulecache.dat file. |
After the Field Service application is configured, create the assignment rule that uses the assignment availability feature.
Use the following procedure to create a field service availability assignment rule.
To create a field service assignment rule
Create the assignment rule by navigating to the Administration - Assignment screen, and then the Assignment Rules List view.
In the Assignment Rules List, choose Edit, then New Record.
In the new record, enter the following settings:
Name = West Coast Service
Objects to Be Assigned = Service Request
Assignee Filter = One, Best Fit
Click the Check Employee Calendar checkbox to enable the rule for availability-based assignment.
Determine assignment criteria.
Navigate to the Criteria view tab and create Product criteria for the assignment rule. For this example, service representatives are evaluated with the Compare Object to Person comparison method, based on an employee's product knowledge.
Determine assignment criteria values.
Navigate to the Values view and create a new record with Pentium III desktop.
Define employees for the assignment rule.
Navigate to the Assignment Employee view and add West Coast Service Representative and the West Coast Service Manager to the assignment rule.
Release the assignment rule.
When a service request is created with attributes that match both West Coast service representatives, Siebel Assignment Manager, through the Appointment Booking System, assigns the employee who has available time in his or her calendar and work schedule. Optionally, the Appointment Booking System can create an activity in the assigned employee's calendar. For more information about the Appointment Booking System, see Siebel Field Service Guide.
Figure 11-2 shows an example of a field service assignment rule, where:
Rule Group = FS_DISP_RULE GROUP
Candidate Passing Score = 0
The Check Employee Calendar checkbox is activated, thereby enabling the rule for availability-based assignment.
