| Siebel CRM Siebel Mobile Guide: Connected Siebel 2018 E52426-01 |
![]() Previous |
![]() Next |
View PDF |
To use native device features such as location services with your Siebel Mobile connected application, then you must configure the privacy setting for the feature on your mobile device accordingly as shown in the following procedures:
The following procedure shows you how to configure the privacy settings on iOS devices.
To configure the privacy settings on iOS devices
Start your iOS device.
Tap Settings, tap Privacy and then tap Location Services to turn on the setting.
The map functionality is now enabled for Siebel Mobile. For more information about using the map functionality, see "Displaying Location Details in Siebel Mobile".
The following procedure shows you how to configure the privacy settings on Android devices.
To configure the privacy settings on Android devices
Start your mobile device.
Tap Google Settings, tap Location and then tap Location Reporting to turn on the setting.
