| Siebel CRM Partner Relationship Management Administration Guide Siebel 2018 E24800-01 |
![]() Previous |
![]() Next |
View PDF |
The following is an example that describes how a partner can work on opportunities in collaboration with other partner companies. This example consists of the following tasks:
Locating Other Partners and Sending Collaboration Requests (Initiating Partner)
Adding Resources to the Collaboration (Initiating and Invitee Partner)
Monitoring Their Collaborations (Initiating and Invitee Partner)
As the first step, the partner who is the initiator of the collaboration uses the Partner Locator and enters criteria to find other partners to collaborate on this project. For example, it might look for other partners in a specific location with a specific expertise.
After the initiator has located other partners, it navigates to Request Collaboration to send them a message asking them to collaborate. Because the initiator does not necessarily know individuals in the partner company they are inviting to collaborate, the message is sent to the organizations of the invitee.
To locate partners and send collaboration requests
The initiating partner navigates to the Partner Locator screen.
In the Partner Locator, the partner enters criteria to identify other partner companies for this collaboration and clicks Search.
The Partner Locations list appears, listing all partners that match the criteria.
The initiating partner selects the records of all the partner organizations in the list to be invited to collaborate.
The initiating partner checks the Available column of the Partner Locator to see whether a partner organization can be involved in a collaboration.
The partner clicks Request Collaboration.
The Outbound Request form appears.
The partner fills out the Outbound Request form with the information in the following table, and navigates to Send Request.
| Field | Description |
| Initiator | Displays the organization that is initiating the collaboration. |
| Recipients | Displays the partner companies being invited to participate in the collaboration. This list includes the partner companies that were chosen in the Partner Locator. The partner can also click the Multiple Select button and use the Collaboration Organizations dialog box to add or remove partners from the recipient list for the request. |
| Description | Enter a description of the collaboration that gives other partners enough information to decide whether they want to join the collaboration. |
| Request Type | Select the type of collaboration. |
| Request Date | Enter the date of the request. The default is the date created. |
| Expiration Date | Enter the date the request becomes inactive. If the recipients do not respond by this date the request is removed from the recipients' inbox. |
| Name | Enter a name for the collaboration request. |
| Created By | Displays the login of the creator of the request. |
| Created | Displays the date the request was created. |
The collaboration request is in the Inbound Request list of each invitee partner. The partner can accept or reject the request by changing the value in its Status field. The default status of a new request is Pending. The partner changes this value to Accepted or Rejected.
The initiating partner checks the Status field of the request in the Outbound Requests view to see if the request was rejected or accepted.
To accept or reject a collaboration request
The invitee partner navigates to the Partner Collaboration screen, then the Inbound Collaboration Requests view.
In the Inbound Request list, the partner drills down on the name of a new request.
In the Request Status view, in the Status field, the partner chooses Accepted or Rejected.
After invitee partners accept the collaboration, the initiating partner creates the collaboration. When the initiating partner clicks the Create button, the collaboration is created and all the invitees who have accepted the collaboration are copied as participants of the collaboration.
To create a collaboration
The initiating partner navigates to the Partner Collaboration screen, then the Outbound Collaboration Requests view.
In the Outbound Request list, the partner selects the request that has been accepted.
The partner clicks Create Collaboration.
A Collaboration record is created based on the request, and all the invitee partners who accepted the request are copied as participants of the collaboration.
The partner fills out the other fields in the Collaboration form.
When an invitee partner has accepted the collaboration request, a collaboration record is created. The next step is for both the initiating partner and the invitee partner to add resources to the collaboration.
Resources can be the positions of employees in the partner's company or organizations in the partner's company. Each partner in the collaboration adds positions and organizations in its own company.
To add resources to the collaboration
Both the initiating and the invitee partners navigate to the Partner Collaboration screen.
In the Collaborations list, the partner selects a collaboration.
The partner navigates to the Resources view.
In the Resources list, the partner adds a record and selects resources, using the following fields.
| Primary | Select a resource from this list. |
| Resource Name | The name of the resource, entered automatically when you select the resource using the Primary list. |
| User ID | If the resource is a position, the employee's login ID is entered automatically when you select the resource using the Primary list. |
| Organization | If the resource is an organization, the organization is entered automatically when you select the resource using the Primary list. |
| Type | The type of the resource, position, or organization, entered automatically when you select the resource using the Primary list. |
| Description | The description of the resource, entered automatically when you select the resource using the Primary list. |
| Start Date | The date when the resource becomes available, entered automatically when you select the resource using the Primary list. |
| End Date | The date when the resource is no longer available, if one exists, entered automatically when you select the resource using the Primary list. |
After the collaboration is set up, the partner companies that are collaborating can share opportunities, service requests, quotes, orders, campaigns, accounts, contacts, projects, and other information.
For example, when a partner company in the collaboration works on an opportunity, it can share the opportunity and associated information with the other partner company, assigning the opportunity to any employee or organization in the other partner company that is a resource in the collaboration.
To share an opportunity with another partner company
The partner navigates to the Opportunities screen.
The partner drills down on an existing opportunity or creates a new opportunity and enters information in the record and More Info form.
The partner clicks Collaborate.
The Grant Access to Collaboration Resources dialog box appears, listing all positions and organizations in other partner companies with which this partner employee has a relationship.
In the dialog box, the partner selects Resources and clicks OK.
Partner positions that were selected are added to the sales team for the opportunity and can see it in the My Opportunities view. Partner organizations that were selected are added to the organization team for the opportunity and can see it in the All Opportunities view.
At any time, a partner company can get an overview of all its collaborations.
To monitor its collaborations
The partner navigates to the User Profile screen, then the Company Profile view.
The partner navigates to the Collaborations view.
A list of all the partner company's collaborations appears.
In the Collaboration list, the partner selects a collaboration.
All of the resources for this collaboration are displayed in the Resources list, which appears after the Collaboration list.
Throughout the process, the brand owner can view all collaborations that partners have created, to monitor partner collaborations.
The brand owner can also view the opportunities, service requests, and other information being shared in the collaboration by using the appropriate view, such as the All Opportunities Across Organizations view.
To monitor all partner collaborations
Navigate to the Partners screen, then the Partner List view.
Drill down on the name of a partner company whose collaborations you want to see.
Navigate to the Collaborations view.
In the Collaboration list, select a collaboration.
