| Siebel CRM Partner Relationship Management Administration Guide Siebel 2018 E24800-01 |
![]() Previous |
![]() Next |
View PDF |
Siebel PRM is fully configurable using Siebel Tools and any HTML editor or Web authoring application. You can configure the following:
Look and Feel. You can configure the look and feel of Siebel PRM to be consistent with the look and feel of your own Web site.
Data Presentation. You can configure business objects, business components, and fields presented in Siebel PRM in the same way that you do in other Siebel Business Applications. For example, you can add special fields or remove fields that are not needed in your business.
Architecture and Performance Preferences. You can set logging, file size, timeout, and other system preferences.
Caution: When you configure Siebel PRM, you must not remove the logout page that appears when the user navigates to Logout, and instead display the anonymous user home page. If you do, the server does not terminate the session. Server sessions could accumulate and exceed the server's maximum. |
For information about configuring Siebel PRM, see Using Siebel Tools.
