| Siebel CRM Performance Tuning Guide Siebel 2018 E24801-01 |
![]() Previous |
![]() Next |
View PDF |
This chapter describes configuration options that affect the performance and throughput of the Siebel Web Client and provides guidelines for tuning the client to achieve and maintain optimal performance and scalability. It contains the following topics:
The following chapters in this guide also relate to Siebel Web Client performance:
For performance considerations for Application Object Manager, see Chapter 3, "Tuning the Siebel Application Object Manager for Performance."
For performance considerations related to configuring Siebel applications, see Chapter 12, "Tuning Customer Configurations for Performance."
For performance considerations related to Siebel Application Interface and to server operating systems, see Chapter 13, "Tuning Operating Systems for Performance."
For more information, see the following documents on the Siebel Bookshelf:
Siebel Deployment Planning Guide
Siebel Installation Guide for the operating system you are using
Deploying Siebel Open UI
Siebel System Administration Guide
Siebel Security Guide
Siebel Remote and Replication Manager Administration Guide
Desktop Integration Siebel Agent Guide
Certifications tab on My Oracle Support
