| Siebel CRM Performance Tuning Guide Siebel 2018 E24801-01 |
![]() Previous |
![]() Next |
View PDF |
Session communications refers to using Communications Server components to enable contact center agents or other users to handle interactive communications work items. For example, Siebel CTI supports this capability, enabling agents to handle voice calls using the communications toolbar.
It is important to understand the infrastructure that supports session communications in order to prevent or address performance issues in this area.
Session communications performance is addressed in this topic and in:
Session communications are supported in the Siebel Server environment primarily by the following components:
Communications Session Manager (CommSessionMgr). This server component manages interactive communications work items such as voice calls.
Siebel Application Object Manager. This server component manages application sessions for end users who use the Siebel Web Client, including users who handle communications work items (agents). Interactive communication requests from agents typically go through Siebel Application Object Manager. For more information about Siebel Application Object Manager, see Chapter 3, "Tuning the Siebel Application Object Manager for Performance."
Server Request Broker (SRBroker). This server component handles communications between the Siebel Application Object Manager and certain other Siebel Server components, including CommSessionMgr.
For example, when a call center agent using Siebel CTI makes a call through the communications toolbar, the request goes from Siebel Application Object Manager to CommSessionMgr by way of SRBroker.
SRBroker is used whether CommSessionMgr runs on the same computer as the Siebel Application Object Manager, or on a different computer. For more information about such scenarios, see "Topology Considerations for Session Communications". For more information about SRBroker, see "Tuning Server Request Broker (SRBroker)".
You might also be using the following components in your Siebel Server environment and communications infrastructure:
Communications Configuration Manager (CommConfigMgr). Optionally used to cache communications configuration data.
Communications Inbound Receiver (CommInboundRcvr). For more information, see "Siebel Email Response Infrastructure".
Communications Inbound Processor (CommInboundProcessor). For more information, see "Siebel Email Response Infrastructure".
Communications Outbound Manager (CommOutboundMgr). Sends outbound email or other types of messages.
You might be using third-party product modules such as CTI middleware, communications driver, and communications configuration; routing products; predictive dialers; interactive voice response modules; email servers; fax servers; and so on. For more information about working with third-party CTI middleware products, see Siebel CTI Administration Guide. For more information about working with third-party email servers, see Siebel Email Administration Guide.
