| Siebel CRM Performance Tuning Guide Siebel 2018 E24801-01 |
![]() Previous |
![]() Next |
View PDF |
The term Siebel Application Object Manager refers to any of several Siebel Server components that support users accessing Siebel applications through the Siebel Web Client and the Siebel Application Interface.
A different Siebel Application Object Manager component is provided for each base application among the Siebel Business Applications, and for each installed and deployed language in which you can run your Siebel applications. For example:
Call Center Object Manager (SSCObjMgr_enu) is the Siebel Application Object Manager for Siebel Call Center in a U.S. English environment.
Sales Object Manager (SSEObjMgr_fra) is the Siebel Application Object Manager for Siebel Sales in a French environment.
Self Service Object Manager (SServiceObjMgr_jpn) is the Siebel Application Object Manager for Siebel Self Service in a Japanese environment.
When configured appropriately, Siebel Application Object Manager components on your Siebel Servers can use memory and CPU resources efficiently, and can communicate efficiently with the Siebel database, the Siebel Application Interface, and other components in the Siebel Enterprise.
The multiprocess, multithreaded model for Siebel Application Object Manager components provides scalability to support deployments with a wide range of concurrent Siebel application users.
The overall performance of the Siebel Application Object Manager contributes significantly to the response time as experienced by your end users.
