| Siebel CRM Performance Tuning Guide Siebel 2018 E24801-01 |
![]() Previous |
![]() Next |
View PDF |
This topic describes how you can configure settings for your Microsoft Windows operating system to optimize the performance of Siebel Business Applications.
For a server computer on which you install Siebel Business Applications software, changing the data throughput setting from Maximize data throughput for file sharing (default) to Maximize data throughput for network applications can result in the following benefits:
Better Symmetrical Multi-Processing (SMP) scalability
Improved networking performance
Allocation of more physical memory for your Siebel applications
Note: Where the Siebel database is on a server computer running Microsoft SQL Server, the setting Maximize data throughput for network applications is set by default, and is also generally recommended for optimal performance. Whether to keep or change this default depends on how you are using the server computer. |
For more information about these settings, see Microsoft's documentation.
You can expand the per-process address limit from 2 GB to 3 GB. This setting reduces the amount of physical RAM available to the operating system from 2 GB to 1 GB. The difference (1 GB) is allocated to your applications. This feature is referred to as 4GT RAM tuning. For information about how to configure this setting, see Microsoft's documentation.
Note: Each Siebel process (Siebel Application Object Manager) cannot use more than 2 GB of RAM. |
