Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Siebel Product Administration Guide > Siebel Configurator UI Properties > Using User-Defined UI PropertiesAfter you give a name to a user-defined UI property, you can use the property by using the appropriate JavaScript syntax.
For an example of how user-defined UI properties can be used, see the use of the UI variable in the topic Creating a New Base Theme Template. |
Siebel Product Administration Guide | Copyright © 2018, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
