Siebel Product Administration Guide > Product Attributes with Business Component Domains > Process of Creating an Attribute with a Business Component Domain > Adding the Attribute to a Selection PageThis step creates the attribute in the class system and defines where it displays in the selection pages. It replaces configuring the originating applet step in the Oracle's Web Tools process for creating a pick applet. This task is a step in Process of Creating an Attribute with a Business Component Domain. The attribute data type must be the same as the data type of the business component field from which the attribute value will come. For example, if the data type of the business component field is Boolean, the attribute data type must be Boolean. The application does not verify that the attribute data type and the business component field data type are the same. In the User Interface view, you do not need to pick a UI control for the attribute. When you define the PickMap01 UI property on the attribute, the application automatically assigns a text field with select button to the attribute. When you select a record from the pick applet, the specified field in the record displays in the attribute text box. If you select a UI control for the attribute, it will be overridden by the text box with select button. To add the attribute to a selection page
| Siebel Product Administration Guide | Copyright © 2018, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
