Siebel Product Administration Guide > Configuration Constraints > Activating and Deactivating Configuration ConstraintsWhen you create a constraint, it may be active or inactive by default:
An active constraint is used to compute all solutions (if the date is within the start and end date of the constraint). When you deactivate a constraint, it is not used to compute solutions. One reason for deactivating a constraint is to help you test constraints in Validate mode. You can deactivate a group of constraints and then activate them one at a time to see how each affects the product's behavior when it is being configured. Another reason to deactivate constraints, is when you want to release a version of a product that does not require a constraint to be active. You can deactivate the constraint and then release the product. The constraint is inactive in the released version and is not used to compute solutions.
Siebel Product Administration Guide | Copyright © 2018, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
