Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Siebel Product Administration Guide > Siebel Configurator Technical Reference > Revising the Default CardinalitiesWhen you create a relationship in a customizable product, you can specify a minimum, maximum, and default cardinality. If you do not specify cardinalities, the application uses the following defaults: If you do not specify cardinalities this means that users are not required to select any items from the relationship and are limited to selecting a maximum of 999 items. You can change these defaults as needed. For example, you can set the maximum application default cardinality to a number larger than 999. To revise the default cardinalities
Siebel Product Administration Guide | Copyright © 2018, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
