| Siebel CRM System Administration Guide Siebel 2018 E24823-01 |
![]() Previous |
![]() Next |
View PDF |
This topic lists the administration tasks applicable to Siebel Servers. It includes the following information:
Related Topics
Chapter 2, "Siebel Enterprise Server Architecture"
"Administering the Siebel Server System Service"
Related Books
Siebel Installation Guide for the operating system you are using
Siebel System Monitoring and Diagnostics Guide
This topic describes how to start a Siebel Server.
Note: In order to start the Siebel Server, the Siebel Server system service must be running. |
If the Auto Startup Mode (alias AutoStart) Siebel Server parameter is set to the default value of True, then the Siebel Server starts automatically when the Siebel Server system service is started.
Note: Starting a Siebel Server starts the default number of tasks, as defined in the Default Tasks (alias DfltTasks) parameter, for each background-mode component. |
This topic is part of "Administering Siebel Servers".
To start a Siebel Server
Navigate to Administration - Server Management screen, then the Enterprises view.
In the Servers list, select the Siebel Server of interest.
Click Startup.
The State field changes to Starting Up.
This topic describes how to shut down a Siebel Server.
Caution: If you shut down the Siebel Server that is hosting your current Siebel Web Client session, then you lose connection to the Siebel Server and cannot restart the Siebel Server by using the Siebel Web Client. In such a case, you must restart the Siebel Server by using the Siebel Developer Web Client or the Server Manager command-line interface. You can shut down and restart Siebel Servers that do not host your Siebel Web Client session without losing your connection. |
To shut down a Siebel Server
Click Shutdown.
The State field changes to Shutting Down.
Note: Shutting down the Siebel Server does not automatically shut down the Siebel Server system service. In some cases, you must shut down not only the Siebel Server, but also the Siebel Server system service. |
