| Siebel CRM System Administration Guide Siebel 2018 E24823-01 |
![]() Previous |
![]() Next |
View PDF |
This topic describes how to delete a Siebel Server component definition.
Caution: Make sure that no active server components use the component definition that you want to delete. If you are in doubt, then deactivate the component definition rather than delete it. |
To delete a Siebel Server component definition
Navigate to the Administration - Server Configuration screen, then the Enterprises view.
Select the Component Definitions view tab.
In the Component Definitions list, select the component definition of interest.
Click Delete.
Related Topics
"About Siebel Server Component Definitions"
