| Siebel CRM System Administration Guide Siebel 2018 E24823-01 |
![]() Previous |
![]() Next |
View PDF |
The Siebel Enterprise Server is a logical grouping of Siebel Servers that supports a group of users accessing a common Siebel database. The Siebel Enterprise Server can be configured, managed, and monitored as a single logical group, allowing the Siebel administrator to start, stop, monitor, or set parameters for Siebel Servers within a Siebel Enterprise Server. You must configure the Siebel Enterprise before you can configure the Siebel Server.
You can set some Siebel Server parameters at the Siebel Enterprise Server level, and these parameters apply to every Siebel Server and component operating within that Siebel Enterprise Server. Other parameters can be adjusted at the Siebel Server or component level to support fine-tuning your deployment.
Parameter settings are inherited unless overrides are in effect, as follows:
If a parameter is set at the server level, then the server-specific value overrides the Siebel Enterprise Server parameter setting on that server.
If a parameter is set at the component level, then the component-specific value overrides the enterprise-level or server-level parameter setting on that component.
Each Siebel Server belonging to a Siebel Enterprise Server must connect to the same Siebel database in the same database server.
The Siebel Enterprise Server itself has no processes and, therefore, cannot have a state.
For more information about configuring the Siebel Enterprise Server, see "Configuring the Siebel Enterprise Server".
