Testing Siebel Business Applications > Usage Pattern Tracking and Conversion to Keyword Scripts > Importing the Test Scripts >
Post Import Options
You can perform the following tasks after importing the scripts from the Script Pane:
- You may choose to add verification points to the existing scripts and use the play option to playback the edited script from the Sitemap-> Release-> Test Scripts View Screen.
- You can export the script as an xml to import it to a different environment from the Sitemap-> Release -> Test Scripts View screen.
- Associate test scripts to Test sets.
