Software Packaging
The Release P-Cz3.1.0 build image is labeled nnPCz310.bz. The image is compressed by the zlib software library and includes all software components needed to install and operate the Oracle Enterprise Communications Broker.
Note that you must obtain a license if you want to operate with TLS. The procedure to obtain this license is documented herein.
		  Broker software delivered for virtual machines includes the following
		packages:
| Image Name | Description |
| nnPCz310.bz | Standalone compressed image - This .bz image
				  package is primarily used to load and operate the
		  Broker software as an appliance.
				   You can also use the .bz image as a load image to existing virtual machines. Create your virtual machine according to specifications. Then copy this image to your machine ( /code) and point your boot parameters to it.  |
| nnPCz310-img-bin.ova | Virtual Machine Template - Import to virtual machine hypervisor to create the entire machine. |
