Display Log Files The Oracle Enterprise Communications Broker (OECB) allows you to view log files without needing to download them. Access the File management page. ClickSystem, File management. The OECB displays the system navigation panel to the left of the associated controls. On the File management page, select the Log file type from the drop-down list. The OECB displays file list, displaying all log file categories. Expand a log file category and select a log file by selecting the check box by the file name. The OECB enables the View control. Click View. The OECB displays the Viewing log:[filename] dialog with the log file's contents.
