Cipher List Configuration
When you select All for the cipher list in the tls-profile configuration, the system displays a warning that the cipher list includes weak ciphers. For example:
Warning: tls-profile[sd] contains the following weak cipher(s): TLS_DHE_RSA_WITH_3DES_EDE_CBC_SHA TLS_DHE_RSA_WITH_AES_256_CBC_SHA TLS_RSA_WITHAES_256_CBC_SHA TLS_DHE_RSA_WITH_AES_128_CBC_SHA.
You may need to adjust the cipher list according to your security requirements.
