SNMP Support
The Oracle Enterprise Communications Broker provides SNMP support for the Rejected Messages data, so you can access this information externally. The new MIB objects are:
apSysRejectedMessages OBJECT-TYPE
SYNTAX Counter32
MAX-ACCESS read-only
STATUS current
DESCRIPTION
"Number of messages rejected by the SD due to matching criteria."
::= { apSysMgmtMIBGeneralObjects 18 }
apSysMgmtRejectedMesagesThresholdExeededTrap NOTIFICATION-TYPE
OBJECTS { apSysRejectedMessages }
STATUS current
DESCRIPTION
" The trap will be generated when the number of rejected messages exceed the configured threshold within the configured window."
::= { apSystemManagementMonitors 57 }
apSysMgmtRejectedMessagesGroup OBJECT-GROUP
OBJECTS {
STATUS current
DESCRIPTION
"Objects to track the number of messages rejected by the SD."
::= { apSystemManagementGroups 18 }
apSysMgmtRejectedMessagesNotificationsGroup NOTIFICATION-GROUP
NOTIFICATIONS {
STATUS current
DESCRIPTION
"Traps used for notification of rejected messages"
::= { apSystemManagementNotificationsGroups 26 }
apSmgmtRejectedMessagesCap
AGENT-CAPABILITIES
PRODUCT-RELEASE "Acme Packet SD"
STATUS current
DESCRIPTION "Acme Packet Agent Capability for enterprise
system management MIB."
SUPPORTS APSYSMGMT-MIB
INCLUDES {
apSysMgmtRejectedMessagesGroup,
::= { apSmgmtMibCapabilities 37 }
