SIP Manipulation Fields
Descriptions of the applicable Oracle Enterprise Communications Broker configuration fields are provided below:
- Name—Enter the unique identifier for this SIP Manipulation. This is the name the user selects when applying this SIP manipulation. There is no default for this value.
- Description—Enter a text description for this SIP Manipulation. This is not an operational field.
Split headers—Enter a comma separated list of headers that the system separates prior to executing the manipulation. Example values are:
Allow,P-Asserted-Identity
- Diversion,Allow
Join headers—Enter a comma separated list of headers that the system joins together after the manipulation execution is complete. Example values are:
- Diversion,Allow
