ENUM Example Configuration
This example provides for the requirement that the signaling make an ENUM dip to resolve some element of the overall signaling path. The configuration must be able to provide ENUM resolutions to provide for the following deployment.
This configuration assumes the agent ESBC1 does not have a configured IP address. In addition, all numbers beginning with 5 are routed to ESBC1. To provide resolution for ESBC1, create an ENUM configuration as follows. In this example, the ENUM configuration includes only one server.
| Hostname | Domain | Servers | Number Trans Mode | Number of Digits |
| enumsrv1 | acme.com | 192.168.2.2 |
Configure a route for all 5-digit extensions beginning with a 5 to the agent named ENUM.
| Route # | Source Agent | Calling number | Called number | Dest Agent | Route | Cost |
| #1 | * | 5xxxx | * | enum:enumsrv1 |
The following table explains the purpose of the route in the preceding table.
| Route # | Description |
| #1 | For traffic destined to a five-digit number beginning with 5, go to ENUM server to resolve the address of ESBC1. |
