Editing an LST File
Recall that LST editing is available via the Registrar configuration. This, in fact defines the registrar as using the LST. Select the LST from the drop-down list and click the Manage LST button to display the Edit Local subscriber table dialog, from which you can add, change, copy and delete users from the LST.
Additional dialog controls include:
- Verify— Parse the LST for format errors and report if the syntax/format is incorrect.
- Save—Dismiss the dialog and save all changes.
- Compare—Identify the changes made to this LST since the last save.
- Change secret—Change the hash secret used to encrypt username, digest realm and password.
- Close—Dismiss the dialog without saving changes.
Perform the following steps to add a user to the LST:
