Define a Policy
The Policy icon on the Oracle Enterprise Communications Broker (OECB) Configuration tab provides access to the policy list and configuration dialogs, where you can define and manage policies.
- Analyze traffic patterns and message content before configuring a custom policy.
- Identify the message contents and metadata that allows a policy to uniquely target the traffic.
- Configure any agents the you want to use for redirected calls.
Use the following
procedure to add a new policy or modify an existing one.
Access the Policy
object. Click
Configuration,
Policy.
The OECB displays the Policy Entries page.
On the Policy
Entries page, do one of the following:
- ClickAdd to create a new policy.
- Click a policy in the policy list.
Enter or edit the
following information.
Parameters Instructions Name Enter a name for the policy. Description Enter descriptive text that explains the purpose of the policy. Conditions Set the conditions under which the system performs the actions that you specify. For codec-condition, do the following: - Click Add.
- Click codec-condition.
- On the Add
Policy / codec condition page, do the following:
- Name—Enter a name for the codec condition.
- Do one
or both of the following:
- Contains Codecs—Click Add, select a codec from the drop-down list, and click either OK or Apply/Add another.
- Missing Codecs—Click Add, select a codec from the drop-down list, and click either OK or Apply/Add another.
- Click OK.
For time-condition, do the following: - Click Add.
- Click time-condition.
- On the Add
Policy / time condition page, do the following:
- Name—Enter a name for the time condition.
- Days—Click Add, select a day from the drop-down list, and click either OK or Apply/Add another.
- Start time—Set the time when you want the condition to start on the specified day.
- End time—Set the time when you want the condition to end on the specified day.
- Click OK.
Actions Set the one or more actions that you want the system to perform for each specified condition. For routing-action, do the following: - Click Add.
- Click routing-action.
- On the Add
policy / routing action page, do the following:
- Enter a unique name for the action.
- Select a routing mode from the drop-down list.
- Click OK.
For redirect-action, do the following: - Click Add.
- Click redirect-action.
- On the Add
policy / redirect action page, do the following:
- Name—Enter a unique name for the action.
- Redirect to agent—Select an agent to redirect the call to before sending the call to the destination.
- Hairpin signalling—Select to enable rerouting a call back to the OECB from a redirect agent before sending the call to the destination.
- Click OK.
For outbound-translation-action, do the following: - Click Add.
- On the Add
policy / outbound translation action page, do the following:
- Egress number translation mode—Select a mode from the drop-down list.
- Number of digits for n digit dialing—If you selected n-digit-dialing as the number translation mode, enter the number of digits the OECB must send to the agent. Range: 0-25.
- Prepend prefix on egress—Specify the number of digits to prepend to the outbound number after translation. Valid entires include telephony digits 0-9, star, pound, and A-D. Max: 25 digits.
- Click OK.
For constraints-action, do the following: - Click Add.
- On the Add
policy / constraints action page, do the following:
- Ignore constraints—Select to ignore call admission control restraints. Default: Disabled.
- Click OK.
For header-normalization-action, do the following: - Click Add.
- On the Add
policy / header-normalization action page, do the following:
- Header
normalization rules—Click
Add, and do the
following:
- Header name—Enter the name of the SIP header to normalize with dialing rules. Required.
- Dialing context—Select a dialing context from the drop-down list.
- Result store—Specify the temporary variable name to store the result of the dialing rules on the SIP header.
- New value—Enter the result name to use as the new value in the SIP header. The system does not change the value of the SIP header unless you specify a value.
- Click OK.
For cnam-masking-action, do the following: - Click Add.
- On the Add
policy / cnam masking action page, do the following:
- Name—Name—Enter a unique name for the action.
- Display name—Enter the caller name replacement value to display in the SIP From header. For example, your company name.
- Click OK.
- Click OK.
- Save the configuration.
You must apply the policy to the Registrar and any route that you want by
way of the
OECB Registrar or route
configuration dialogs.
