Notable Event Reports
The Notable Events Report contains all logged sessions with a notable event associated with the session on the Oracle Enterprise Communications Broker (OECB).
The columns that display on the Notable Events Report page depend on the columns that you selected in the procedure, "Customizing the Page Display."
The following table describes the columns that Notable Events Report page can display.
| Start Time | Timestamp of the first SIP message in the call session. |
| State | Status of the call or media event session. Valid
values are:
INITIAL Session for which an INVITE or SUBSCRIBE was forwarded. EARLY Session received the first provisional response (1xx other than 100). ESTABLISHED Session for which a success (2xx) response was received. TERMINATED Session that has ended by receiving or sending a BYE for an “Established” session or forwarding an error response for an “Initial” or Early session. The session remains in the terminated state until all the resources for the session are freed up. FAILED Session that has failed due to a 4xx or 5xx error code. |
| Call ID | Identification of the call source. Includes the phone number and source IP address. |
| Request URI | Uniform Resource Identifier (URI) formatted string that identifies a resource via a protocol, name, location, and any other applicable characteristic, and is sent by the OECB in REQUEST headers. |
| From URI | URI formatted string that identifies the call source information. |
| To URI | URI formatted string that identifies the call destination information. |
| Notable Event | Indicates if a notable event has occurred on the
call session. Valid values are:
short session - Sessions that don’t meet a minimum configurable duration threshold; Session dialogue, captured media information and termination signalling; Any event flagged as a short session interesting event. local rejection - Sessions locally rejected at the OECB for any reason (for example, Session Agent (SA) unavailable, no route found, SIP signalling error, etc.); Session dialogue, capture media information and termination signaling; Any event flagged as a local rejection interesting event. |
| Session ID | Identification assigned to the call session. |
| Ingress Src Addr | Source IP address of the incoming call or media event. |
| Ingress Src Port | Source port of the incoming call or media event. |
| Egress Dest Addr | Destination IP address of the outgoing call or media event. |
| Egress Dest Port | Destination port of the outgoing call or media event. |
| Object ID | ID number of the object in a row. Use to aid troubleshooting. |
The following table describes the buttons on Notable Events Report page.
| Search | Allows you to specify parameters for performing a search for specific session summary records within the current report. |
| Show all | Displays all of the session summary records in the Session Report. |
| Ladder Diagram | Displays a Ladder Diagram of a specific record in the table. The Ladder Diagram displays detailed information about a call session or media event. |
| Export Session Details | Exports the SIP messages and media events associated with the selected session, to a file in text format on the local machine. |
| Export Summary | Exports all logged session summary records to a file in text format on the local machine. |
