Delete a File
Use this procedure to delete a file from the Oracle Enterprise Communications Broker (OECB).
You can delete any of the following file types from your local server or PC to the OECB:
- Local subscriber table (LST)
- SPL Plug-in (SPL)
- Backup configuration
You can select a single or multiple files to delete.
