Audit Logs
The Oracle Enterprise Communications Broker (OECB) can record user actions in audit logs by way of the Web GUI. The audit logs record the creation, modification, and deletion of all user-accessible configuration elements, as well as attempted access to critical security data such as public keys. For each logged event, the system provides the associated user-id, date, time, event type, and success or failure data.
You can configure the system to record audit log information in either verbose mode or brief mode. Verbose mode captures the system configuration after every change, and displays both the previous settings and the new settings in addition to the event details. Brief mode displays only the event details. Although you can specify the recording mode, you cannot specify which actions the system records. The following list describes the actions that the system records.
| Global |
| Home tab |
| Configuration tab |
| Widgets tab |
| System tab |
| Monitor and Trace tab |
The system writes audit log events in Comma Separated Values (CSV) lists in the following format:
{TimeStamp,
src-user@address:port,Category,EventType,Result,Resource,Prev,
Detail}
The following list describes each value written to an audit log event.
| TimeStamp | Shows the time when the system wrote the event to the audit log. |
| src-user@address:port | Identifies the system that wrote the audit log line. |
| Category | Classifies the event as:
| EventType | Identifies the action that caused the event as:
| Result | Identifies the outcome of the event as:
| Resource | Describes the action within the event. Some of the
numerous actions that the system can log include:
| Prev—(verbose mode) | Displays the setting prior to this change. |
| Details—(verbose mode) | Displays additional information about the change,
depending on the following event types:
As the OECB records audit log data, users with admin privileges can read, copy, and download that information from the Web GUI. No one can delete or edit the original log. You can View, Refresh, and Download audit logs by way of the System tab. When you click File Management, the system displays the File Type drop-down list, which includes "Audit Log" as a selection.
- The specified amount of time since the last transfer elapsed.
- The size of the audit log reached the specified threshold. (Measured in Megabytes)
- The size of the audit log reached the specified percentage of the allocated storage space.
The OECB transfers the audit logs to a designated directory on the target SFTP server. The audit log file is stored on the target SFTP server with a filename in the following format: audit<timestamp>. The timestamp is a 12-digit string the YYYYMMDDHHMM format.
- Configure secure FTP push. See "Secure FTP Push Configuration."
- Configure audit logging. See "Configure Audit Logging."
You can configure the Oracle Enterprise Communications Broker (OECB) to securely send audit log files to an SFTP push receiver for storage. Configure secure FTP push before you configure audit logging.
It is also common for the SFTP server to run the Linux operating system. For Linux, the command ssh-keygen-e creates the public key that you need to import to the OECB. The ssh-keygen-e command sequence requires you to specify the file export type, as follows.
[linux-vpn-1 ~]# ssh-keygen -e Enter file in which the key is (/root/.ssh/id_rsa/): /etc/ssh/ssh_host_rsa_key.pub
If you cannot access the SFTP server directly, but you can access it from another Linux host, use the ssh-keyscan command to get the key. An example command line follows.
root@server:~$ssh-keyscan -t dsa sftp.server.com
Configure Secure FTP Push with Public Key Authentication
For increased security when sending files from the Oracle Enterprise Communications Broker (OECB) to an SFTP server, you can choose authentication by public key exchange rather than by password. To use a public key exchange, you must configure public key profiles on both devices and import the key from each device into the other.
The following list of tasks shows the process for configuring authentication by public key between the OECB and an SFTP server. For each step in the process, see the corresponding topic for detailed instructions.
- Generate an RSA public key on the OECB. See "Generate an RSA Public Key."
- Create a DSA public key on the SFTP server. See "Generate a DSA Public Key."
- Import the DSA public key from the SFTP server into the OECB using the known-host option in the Import Key dialog. See "Import a DSA Public Key."
- Add the RSA public key to the authorized_keys file in the .ssh directory on the SFTP server. See "Copy the RSA Public Key to the SFTP Server."
Add a public key profile on the Oracle Enterprise Communications Broker (OECB) and generate an RSA key. You will later import the RSA key into the SFTP server to enable authentication by way of public key exchange with the OECB.
- Generate a DSA public key.
Generate and save a DSA public key on the SFTP server. You will later import the DSA key into the Oracle Enterprise Communications Broker (OECB) to enable authentication by way of public key exchange with the SFTP server.
- Run the following command on the SFTP server:
ssh-keygen -e -f /etc/ssh/ssh_host_dsa_key.pub | tee sftp_host_dsa_key.pub
- Save the key to the authorized_keys file in the .ssh directory on the SFTP server.
- Import the DSA key into the OECB.
Import a DSA public key from the SFTP server into the Oracle Enterprise Communications Broker (OECB).
- Generate and save a DSA public key on the SFTP server.
Perform the following procedure on the OECB and select "known-host" for type.
Copy the RSA public key to the SFTP server.
Copy the RSA public key from the from the Oracle Enterprise Communications Broker (OECB) to the authorized_keys file in the .ssh directory on the SFTP server.
- Confirm that the .ssh directory exists on the SFTP server.
- Confirm the following permissions: Chmod 700 for .ssh and Chmod 600 for authorized_keys.
When adding the RSA key to the authorized_keys file, ensure that no spaces occur inside the key. Insert one space between the ssh-rsa prefix and the key. Insert one space between the key and the suffix. For example, ssh-rsa <key> root@1.1.1.1.
- Access the SSH file system on a configured SFTP server with a terminal emulation program.
- Copy the RSA key to the SFTP server, using a text editor such as vi or emacs, and paste the RSA key to the end of the authorized_keys file.
The Oracle Enterprise Communications Broker (OECB) provides a means of tracking user actions through Audit Logs. You can specify how the system records audit log information, and where to send the logs for archiving. You can configure the system to record in either brief or verbose mode. Verbose mode captures the system configuration after every change, and displays both the previous and new settings in addition to the event details. Brief mode displays only the event details.
- Configure one or more push receivers to receive the audit logs. See the documentation for the receiver.
- If you want to use public keys for authentication between the OECB and the push receiver, configure public key profiles on both devices before configuring audit logging. See "Configure Secure File Transfer with Public Keys."
