SIP Authentication Query Configuration Fields
To configure the Oracle Enterprise Communications Broker to specify an alternate authentication field in a remote database for the purpose of authenticating registration attempts:
- On the Modify ldap-config dialog, expand the sip-auth-query section, directly under the routing-query section, using the down arrow to expose the applicable fields.
- Query Digest Username attribute—Enter the name of the attribute where the digest username is stored in your LDAP database. The default is sAMAccountName, which is the standard Active Directory username attribute.
- Digest Auth attribute—Enter the name of the attribute where the digest authentication hash is stored in your LDAP database. The default value is orclDigestPwdAttribute, which is a custom field populated by the oidpwdcn password filter.
- Click OK to save your authentication query configuration.
