Upload a File
Use the following procedure upload a file to the Oracle Enterprise Communications Broker (OECB).
You can upload any of the following file types from your local server or PC to the OECB:
- Backup configuration
- Configuration CSV
- Local subscriber table (LST)
- Software image
- SPL Plug-in (SPL)
You cannot upload Log or Audit Log files.You can dynamically activate the “Local route table” and “SPL Plug-in”during the upload process, if required. You can also immediately restore a backup configuration file after an upload is complete.
